8
I am using an Arduino Uno to control an ESC for my (in progress) quadrocopter. I am currently using the servo library to control the ESC, which works great.
Except..
A count of 100 is max speed, meaning I only have 10 speeds between 90 (stopped) and 100 (motor at full power) to correctly run my quadrocopter, I would like to have many more speed options. Any ideas? I'm having a hard time using a PWM signal, I might not be doing it right though.
My current code is here:
#include <Servo.h>
Servo myservo; // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
void setup()
  myservo.attach(8); // attaches the servo on pin 8 to the servo object
void loop()
 int maxspeed=100;
 int minspeed=0;
 int delaytime=5;
 int count;
 for(count=0; count <1; count+=1) {
  for(pos = minspeed; pos < maxspeed; pos += 1) // goes from 0 degrees to 180 degrees
  { // in steps of 1 degree
    myservo.write(pos); // tell servo to go to position in variable 'pos'
    delay(delaytime); // waits 15ms for the servo to reach the position
  for(pos = maxspeed; pos>=minspeed; pos-=1) // goes from 180 degrees to 0 degrees
  if(count>1){
    break;
 myservo.write(92);
 delay(100000);
 myservo.write(90);
 delay(10000000);
5
The servo.write(angle) function is designed to accept angles from 0 to 180. (The value 180 is significantly larger than 100). Could you tell me where in the Servo documentation you read "100 (motor at full power)", so we can fix that typo?
Please change the line
int maxspeed=100; /* wrong */
to
int maxspeed=180;
Also, please run servo.refresh() periodically to keep the servos updated -- perhaps something like:
    myservo.write(pos); // set the servo position
    myservo.refresh(); // tell servo to go to the set position
myservo.write(92);
for( long int delaytime = 0; delaytime < 100000; delaytime+=10 ){
    delay(10);
As mpflaga pointed out, you can get more precision by setting the pulse width directly in microseconds with
myservo.writeMicroseconds(1000); // typical servo minimum; some go down to 600 or less
myservo.writeMicroseconds(2000); // typical servo maximum; some go up to 2500 or more
p.s.: Have you seen "blink without delay" ? That technique makes it much easier to read sensors and update servo positions with consistent heartbeat timing.
  • $\begingroup$ Thank you, I will look into each of those suggestions. To answer your question: I did not read in any doc that servo count 100 was the max power, I figured it out by testing the motor (hobbyking.com/hobbyking/store/…) and finding that above servo count 100, the prop did not seem to spin any faster, giving me a very small operating range. $\endgroup$
    – Toozinger
    Nov 25, 2013 at 17:55
  • $\begingroup$ If that is the case then, you are either your battery cannot supply enough current(check C value), or your propellors are too large(too much load on the motor), or your esc cannot supply enough current(in which case it might get heated up). Please check for all of the above possibilities. $\endgroup$ Jun 24, 2016 at 7:07
Your code uses the typical servo.attach(pin) where you can use the overload of servo.attach(pin, min, max) to set the min and max microseconds of the pulse width to match the desired ranges for you ESC. Additionally to make it a bit more clear where myservo.write(90); is used to set the angle, you can use myservo.writeMicroseconds(1500); to set the duration of the pulse directly in microseconds.
