5
I am about to make an rc car which uses a wifi connection. The body for the car would be made from aluminium and the wifi receiver will be placed inside this aluminium casing.
How do I make sure that this will work?
Would I be forced to change my material or can I just make an extension for the receiver and make sure it is out of the casing?
If so , would that really help me?
  • $\begingroup$ As long as the antenna is outside the casing, radio communications such as wifi should work fine. $\endgroup$
    – David Cary
    Nov 25, 2013 at 4:12
6
You can use an external onmidirectional wifi antenna, like these on ebay.
If your wifi chip does not have a U-FL connector, you can use a SMA to U-FL adapter or directly a SMA Antenna.
Your Wifi signals should be able to penetrate aluminum. Wifi uses radio waves which can go through some thick material. I know that Wifi signals pass through steel. The best way for you to know is to try. If it does not work, drill a hole in your casing and use an antennae.
