Hi i am doing an apriltag following project. I am currently trying to test how to get distance between the tag and the camera. I have subscribed to the AprilTagDetectionArray msg.
My main question is how do i get the distance between the tag and my camera. Should i use the position or the orientation values? I want the robot to detect and then approach the tag.
I tried getting the values from both position and orientation but i am getting the error below.
#!/usr/bin/env python
import rospy
from apriltag_ros.msg import AprilTagDetectionArray
w = 0.0
def tagDetect(msg):
    global w
    w = msg.pose.pose.orientation.w
    w = abs(w)
    rospy.loginfo("w = %s",w)
def listener():
    rospy.init_node("listener",anonymous=True)
    rospy.Subscriber("/tag_detections",AprilTagDetectionArray,tagDetect)
    rospy.spin()
if __name__ == '__main__':
    listener()
but i am getting this error. how do i resolve this??
 [ERROR] [1593270010.489688]: bad callback: <function tagDetect at 0x7f53e4b62a28>
  File "/opt/ros/kinetic/lib/python2.7/dist-packages/rospy/topics.py", line 750, in _invoke_callback
    cb(msg)
  File "/home/zeus/catkin_ws/src/autonav/src/test.py", line 10, in tagDetect
    w = msg.pose.pose.position[0].x
AttributeError: 'AprilTagDetectionArray' object has no attribute 'pose'
Here is the message just in case.
[apriltag_ros/AprilTagDetectionArray]:
std_msgs/Header header
  uint32 seq
  time stamp
  string frame_id
apriltag_ros/AprilTagDetection[] detections
  int32[] id
  float64[] size
  geometry_msgs/PoseWithCovarianceStamped pose
      uint32 seq
      time stamp
      string frame_id
    geometry_msgs/PoseWithCovariance pose
      geometry_msgs/Pose pose
        geometry_msgs/Point position
          float64 x
          float64 y
          float64 z
        geometry_msgs/Quaternion orientation
          float64 x
          float64 y
          float64 z
          float64 w
      float64[36] covariance
  • $\begingroup$ how do i resolve the error? $\endgroup$ Jun 28 '20 at 6:06
I can't comment, so writing this as an answer. Did you try calling msg.detections.pose.pose.orientation.w?
From your message definition hierarchy, is seems pose is under object detections.
