I am using Arduino UNO to read a push button every time it is pressed.Earlier i was simply reading the Digital IO pin to read the count and then i faced the condition of switch debounce regarding which i had asked a question here and get to know that i must use Interrupt instead of reading a digital IO pin but even after using interrupt, i was facing the problem of Switch Debouncing.
So i used this link and code given on this link
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// Variables will change:
int ledState = HIGH; // the current state of the output pin
int buttonState; // the current reading from the input pin
int lastButtonState = LOW; // the previous reading from the input pin
// the following variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long lastDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 50; // the debounce time; increase if the output flickers
void setup() {
pinMode(buttonPin, INPUT);
pinMode(ledPin, OUTPUT);
// set initial LED state
digitalWrite(ledPin, ledState);
void loop() {
// read the state of the switch into a local variable:
int reading = digitalRead(buttonPin);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// only toggle the LED if the new button state is HIGH
if (buttonState == HIGH) {
ledState = !ledState;
// set the LED:
// save the reading. Next time through the loop,
// it'll be the lastButtonState:
lastButtonState = reading;
and change
to 10(means read any thing ina time gap of 10 mili second) as the code says.Now what is happening, code is running on the board and after some time my board get hang and LED stop toggling on any press of push button and then i had to manually reset my board.I also want to add upon a thing that i am also using a serial port in between when LED toggles or switch is pressed.
I am totally confused why this is happening.There can beone possibility that this is happening because i reduced time gap between two consecutive events to 10 from 50 miliseconds and that might be making AVR get hanged and thus require a manual reset.
