I attached two quadrature optical encoders to the wheel of the mobile robot. I also have imu6050 attached to the breadboard to calculate the orientation of the wheel mobile robot localization. I want to know if my code is right and also determine the starting point for the wheel mobile robot using these sensors.
  #include <MPU6050_tockn.h>
  MPU6050 mpu6050(Wire);
  #define ENC_A1  2
  #define ENC_B1  3
  #define ENC_A2  18
  #define ENC_B2  19
  #define wheelbase 88                                           // wheelbase corner-to-corner
  #define count_per_revolution 12                               //(mm)
  #define Lwheel_c 140                                          //(mm)
  #define Rwheel_c 139.9                                        //(mm)
  #define pi 3.142
  #define TWOPI 6.284
  // Main loop refresh period.
  #define REFRESH_MS  50
  // Main serial data connection to computer.
  #define BAUD_RATE   9600
  // Encoder signal line states
  volatile boolean state_a1 = 0;
  volatile boolean state_b1 = 0;
  volatile boolean state_a2 = 0;
  volatile boolean state_b2 = 0;
  // Encoder position
  volatile int enc_pos_1 = 0;
  int enc_pos_prev_1 = 0;
  int enc_pos_change_1 = 0;
  volatile int enc_pos_2 = 0;
  int enc_pos_prev_2 = 0;
  int enc_pos_change_2 = 0;
  // normally on a differential drive system to when moving
  // forwards the wheels are rotating in opposite directions
  int encoder_direction_left = 1;
  int encoder_direction_right = 1;
  // Timing
  unsigned long micros_current = 0;
  unsigned long micros_prev = 0;
  long micros_change = 0;
  /* local variables */
  float dleft;
  float dright;
  float last_theta;
  /* odometer maintains these global accumulator variables: */
  float x_pos;                    // bot X position
  float y_pos;                    // bot Y position
  float wheel_distance;
  float theta;                     /* bot heading in radians minus theta_offset */
  float theta_global;
  /* rate of rotation measurements, used for stasis error detection */
  float wheel_theta;
  float imu_theta;
  long timer;
  void setup() {
  Wire.begin();
  mpu6050.begin();
  mpu6050.calcGyroOffsets(true);
    pinMode(ENC_A1, INPUT);
    pinMode(ENC_B1, INPUT);
    pinMode(ENC_A2, INPUT);
    pinMode(ENC_B2, INPUT);
    state_a1 = (boolean) digitalRead(ENC_A1);
    state_b1 = (boolean) digitalRead(ENC_B1);
    state_a2 = (boolean) digitalRead(ENC_A2);
    state_b2 = (boolean) digitalRead(ENC_B2);
    attachInterrupt(0, interrupt_enc_a1, CHANGE);
    attachInterrupt(1, interrupt_enc_b1, CHANGE);
    attachInterrupt(5, interrupt_enc_a2, CHANGE);
    attachInterrupt(4, interrupt_enc_b2, CHANGE);
    micros_prev = micros();
    Serial.begin(BAUD_RATE);
  void loop() {
   mpu6050.update();
  if(millis() - timer > 1000){
     timer = millis();
    // Calculate elapsed time
    micros_current = micros();
    if (micros_current < micros_prev) {
        micros_change = micros_current + (4294967295 - micros_prev);
    } else {
        micros_change = micros_current - micros_prev;
    // Calculate change in encoder position.
    enc_pos_change_1 = enc_pos_1 - enc_pos_prev_1;
    enc_pos_change_2 = enc_pos_2 - enc_pos_prev_2;
    // Emit data
    Serial.print(enc_pos_change_1);
    Serial.print("\t");
    Serial.print(enc_pos_change_2);
    Serial.print("\t");
    Serial.print(dright);
    Serial.print("\t");
    Serial.print(dleft);
    Serial.print("\t");
    Serial.print(x_pos);
    Serial.print("\t");
    Serial.print(y_pos);
    Serial.print("\t");
    Serial.print(theta);
    Serial.print("\t");
    Serial.print(mpu6050.getAngleX());
    Serial.print("\t");
    Serial.print(mpu6050.getAngleY());
    Serial.print("\t");
    Serial.println(mpu6050.getAngleZ());
    // and update last sampling for next time
    enc_pos_prev_1 = enc_pos_1;
    enc_pos_prev_2 = enc_pos_2;
    micros_prev = micros_current;
    dleft = (enc_pos_change_1) * Lwheel_c;
    dright = (enc_pos_change_2)* Rwheel_c;
    // calculate distance we have traveled since last sampling
      wheel_distance = (dleft + dright)/2.0;
    // accumulate total rotation around our center
    wheel_theta = ((dleft - dright)/wheelbase)*(180/pi); // You can multiply theta * (180.0/PI) to get the heading in degrees
   /* read the YAW value from the imu struct and convert to radians */
   theta_global = ((float)mpu6050.getAngleZ()*TWOPI)/65536.0;
    /* calculate rotation rate-of-change for stasis detector */
    imu_theta = theta_global - last_theta;
    last_theta = theta_global;
   // if (g->yaw_enable) {
    if (mpu6050.getAngleZ()) {
    } else {
    theta += wheel_theta;
    //and clip the rotation to plus or minus 360 degrees
    theta -= (float)((int)(theta/TWOPI))*TWOPI;
    if (theta < -PI) {
      theta += TWOPI;
      }else {
        if (theta > PI)
        theta -= TWOPI;
    x_pos =  x_pos + wheel_distance * cos(theta);
    y_pos =  y_pos + wheel_distance * sin(theta);
   delay(REFRESH_MS);
  // Detect pulses from depth encoder.
  void interrupt_enc_a1() {
    if (!state_a1) {
        state_b1 ? enc_pos_1++: enc_pos_1--;
    state_a1 = !state_a1;
  void interrupt_enc_b1() {
    state_b1 = !state_b1;
  void interrupt_enc_a2() {
    if (!state_a2) {
        state_b2 ? enc_pos_2++: enc_pos_2--;
    state_a2 = !state_a2;
  void interrupt_enc_b2() {
    state_b2 = !state_b2;
