I don't understand where the matrices A and A transpose come from in the equation in this series. I have done a one-dimensional example in the series but I don't see how to derive these matrices in matrix form.
Equation image
The $A$ matrix (sometimes $F$) comes from your equations of motion. There's a technical example on Wikipedia that goes over modeling position and speed of a truck.
You can model speed and position with the following equations:
$$ x = x_0 + \Delta t \dot{x} + \frac{1}{2}\Delta t^2 \ddot{x} \\ \dot{x} = \dot{x}_0 + \Delta t \ddot{x} \\ $$
Assuming your input $u$ is the acceleration ($u = \ddot{x}$), and being more explicit with the coefficients on everything, you could rewrite the above as:
$$ x = \left(1\right)x_0 + \left(\Delta t\right) \dot{x} + \left(\frac{1}{2}\Delta t^2\right) u \\ \dot{x} = \left(0\right)x_0 + \left(1\right)\dot{x}_0 + \left(\Delta t\right)u \\ $$
And then you convert to matrix form:
$$ \left[\begin{matrix} x \\ \dot{x}\end{matrix}\right] = \left[\begin{matrix} 1 & \Delta t \\ 0 & 1 \end{matrix}\right] \left[\begin{matrix} x_0 \\ \dot{x}_0 \end{matrix}\right] + \left[\begin{matrix} \frac{1}{2}\Delta t^2 \\ \Delta t\end{matrix}\right]u $$
The current sample being: $$ x_k = \left[\begin{matrix} x \\ \dot{x}\end{matrix}\right] $$ and the previous sample being: $$ x_{k-1} = \left[\begin{matrix} x_0 \\ \dot{x}_0 \end{matrix}\right] $$
You can then define your "state matrix" $A$ or $F$ as:
$$ A = \left[\begin{matrix} 1 & \Delta t \\ 0 & 1 \end{matrix}\right] $$ and your input matrix $B$ or $G$ as:
$$ B = \left[\begin{matrix} \frac{1}{2}\Delta t^2 \\ \Delta t\end{matrix}\right] $$
And so you have:
$$ x_k = Ax_{k-1} + Bu $$
And then those are used with the output equations:
$$ y_k = Cx_k + Du $$
to form the Kalman filter. These are all standard matrices from the state space representation of a system.
5
  • 2
    $\begingroup$ To expand on this. The value we are estimating is assumed to be a gaussian distribution with $x - \mathcal{N}(x,P)$. Chuck shows how $A$ works on the mean($x$). In your equation you are estimating the covariance. The transpose is used to keep the matrix symmetric, and because the covariance is the variance^2. You essentially need to square the $A$ matrix. Which is accomplished by multiplying by the transpose. A proof of this can be found here(math.stackexchange.com/questions/332441/…) $\endgroup$
    – edwinem
    Jun 5 '20 at 15:31
    $\begingroup$ Thanks, @edwinem ! Op's question was about "where the matrices A and A transpose come from" in the equations, so I tried to answer just that aspect as directly as possible, but this is great context and excellent further reading :) $\endgroup$
    – Chuck
    Jun 5 '20 at 15:34
  • $\begingroup$ I needed the math part too. $\endgroup$ Jun 5 '20 at 17:39
  • $\begingroup$ @heretoinfinity - What do you mean? You need the math part for what? What is missing from the answer I provided, or what can I explain better? $\endgroup$
    – Chuck
    Jun 5 '20 at 19:32
  • 2
    $\begingroup$ The linear algebra and how I ended up with the transpose. I see it in the link with the comment so that's solved. $\endgroup$ Jun 5 '20 at 20:08
