I have 4 3d points(x, y, z). Using these points how can I calculate rotation angle? Consequently, I want to have a 4x4 transformation matrix including rotation and translation information.
4 points are in a plane and they are rectangle and I set the top-left point as the origin of the rectangle coordinate. Look at the bellow pictures.
enter image description here enter image description here Here I only have four 3D points(Xw,Tw,Zw) based on the world coordinate. According to the 4 points, I can calculate 4 points based on the rectangle coordinate. For instance, value [Xr] in P2 is the distance between P1 and P2. And [-Yr] in P3 is the distance between P1 and P3.
Then how could I get rotation angle of the rectangle based on the world coordinate using those information?
Additional information (3d points in the world coordinate):
P1(-401.428, 485.929, 772.921)
P2(-21.4433, 475.611, 772.511)
P3(-400.982, 483.56, 403.703)
P4(-21.589, 473.028, 403.242)
  • $\begingroup$ So you want find the SE(3) transformation between the two sets of four points? Thus preferably represent the rotation with a rotation matrix? $\endgroup$
    – fibonatic
    May 29 '20 at 2:20
  • $\begingroup$ @fibonatic Yes I need a rotation matrix. $\endgroup$ May 29 '20 at 5:13
You want to find a translation vector $t \in \mathbb{R}^3$ and rotation matrix $R \in \mathbb{R}^{3 \times 3}$ such that vectors $p_k \in \mathbb{R}^3$ map to $p_k' \in \mathbb{R}^3$ using
$$ \begin{bmatrix} p_k' \\ 1 \end{bmatrix} = \begin{bmatrix} R & t \\ 0 & 1 \end{bmatrix} \begin{bmatrix} p_k \\ 1 \end{bmatrix}, $$
or equivalently $p_k' = R\,p_k + t$. Since the zero vector in rectangle coordinates should map to P1 in world coordinates it follows that $t$ should be equal to P1 in world coordinates. The rotation matrix can be found by using a solution to Wahba's problem, which in your case can be defined as
$$ \min_{R \in SO(3)} \sum_{k=1}^n a_k\, \|w_k - R\,v_k\|^2, $$
with $w_k = p_k' - t$ and $v_k = p_k$. The weights $a_k$ can be any positive number, often used to indicate how "trustworthy" each vector is and/or normalize with respect to vector length. However, one can always just set all $a_k$ equal to one.
If the world coordinates are subjected to any disturbance it might be that using P1 in world coordinates as $t$ gives a slightly sub-optimal solution. However, the solution proposed in this answer should still give a good approximated optimal solution (with respect to $\sum \|R\,p_k + t - p_k'\|^2$).
Also check this blog post for an alternative solution: http://nghiaho.com/?page_id=671
