I am currently going through all the pixels in an image to determine what is a white pixel. I then have to decide where to drive the bot. I am also using sensor_msgs/Image.msg that I get from the /camera/rgb/image_raw channel.
However, I can't seem to locate any white image with the code but the RGBa values I set in my model in gazebo all have value 1 as shown in the image below the code .
I logged all my values(more than once) with ROS_INFO_STREAM but no values are 255, let alone 3 consecutive ones.
void process_image_callback(const sensor_msgs::Image img)
  const int white_pixel = 255;
  const int image_slice_width = img.step / 3;
  int j = 0;
  bool found = false;
  for (int i = 0; not found and i < img.height; i++)
    for (j; j < img.step-3; j += 3)
      if (img.data[i*img.step + j] == white_pixel)
      ROS_INFO_STREAM("img.data[i*img.step + (j + 0)]" + std::to_string(img.data[i*img.step + (j + 0)]));
      ROS_INFO_STREAM("img.data[i*img.step + (j + 1)]" + std::to_string(img.data[i*img.step + (j + 1)]));
      ROS_INFO_STREAM("img.data[i*img.step + (j + 2)]" + std::to_string(img.data[i*img.step + (j + 2)]));
      // img.data only has one index
      if (img.data[i*img.step +  j     ] == white_pixel and
          img.data[i*img.step + (j + 1)] == white_pixel and
          img.data[i*img.step + (j + 2)] == white_pixel)
          found = true;
          break;
    ROS_INFO_STREAM("End of j loop");
  if (found)
    // go left, forward or right
  else
    // no white pixel seen so stop the bot
gazebo RGBA settings
  • $\begingroup$ why do you expect a white pixel to have an exact value of 255? $\endgroup$
    – jsotola
    May 14 '20 at 0:11
  • $\begingroup$ It has the highest possible value of red, green and blue was my thinking since I set it. Why would it not have that? Oh, I missing the image to show my settings. $\endgroup$ May 14 '20 at 0:32
  • $\begingroup$ I've worked on this same exercise before and didn't need nested for loops. You could borrow that part from mine and see if any pixels = 255 are found. If yes, then there's an issue with your nested for presumably. Here's my code: github.com/abhishek47kashyap/udacity-robotics-software-engineer/… $\endgroup$ May 18 '20 at 5:51
  • $\begingroup$ I suggest you require pixel intensities to be above some specified value instead exactly the value. If the RGB values are all 254, is that not close enough? $\endgroup$
    – Ralff
    May 22 '20 at 1:06
