I am trying to run this youbot ( sample world) from webots, where the controller is implemented in MATLAB, on running the code it pops out the following error seen in the picture attached. I have also however installed the Support for MinGW-w64 C/C++ Compiler, though it still shows the same error. Could someone help a bit? The error is as follows:
Warning: Name is nonexistent or not a directory: C:\Program Files\Webots\lib\matlab
> In path (line 109)
In addpath (line 86)
In launcher (line 23)
The MATLAB "MinGW-w64 C/C++ Compiler" addon is not installed, please install it from: https://fr.mathworks.com/matlabcentral/fileexchange/52848-matlab-support-for-mingw-w64-c-c-compiler
Waiting up to 5 seconds for C:\Users\asus\AppData\Local\Temp\webots_matlab_lock to be deleted by another MATLAB instance.
Deleting C:\Users\asus\AppData\Local\Temp\webots_matlab_lock...
Creating: C:\Users\asus\AppData\Local\Temp\protofile_matlab_2018b_webots_R2020a_revision_1.m
Load Library failed.
Error using loadlibrary
Could not find file allincludes.h.
Error in loadlibrary
Error in launcher (line 74)
loadlibrary( ...
