I created my world with gazebo9 and saved it.
world$ tree
└── myworld
    ├── model.config
    └── model.sd
Now when I start it with
$ gazebo myworld
I get
terminate called after throwing an instance of 'std::bad_alloc'
  what():  std::bad_alloc
Why am I getting a memory error when all this ran fine. Starting Gazebo on its own works.
I am using: Ubuntu 18.04 gazebo9
Question 1 and Question 2 don't have solutions.
I have restarted my virtual machine and still get the same error. In some cases, nothing happens.
You might be confusing Gazebo worlds and models. A world is a single SDF file structured as below:
<sdf version="VERSION">
  <world name="NAME">
    <!-- Included models, links etc. -->
  </world>
</sdf>
For example, these are the contents of the sample /usr/share/gazebo-9/worlds/willowgarage.world world file:
<?xml version="1.0" ?>
<sdf version="1.5">
  <world name="default">
    <include>
      <uri>model://ground_plane</uri>
    </include>
    <include>
      <uri>model://sun</uri>
    </include>
    <include>
      <uri>model://willowgarage</uri>
    </include>
  </world>
</sdf>
In order to pre-load a world at startup time, you pass the path to the file as argument to Gazebo:
$ gazebo /usr/share/gazebo-9/worlds/willowgarage.world
The directory structure you described looks more like that of a model, which in addition to a SDF file also includes a configuration and (optionally) other resources such as meshes, materials etc. As far as I know there's no way to directly load a model at startup time, other than as an element included in a world file.
So to answer your question, the problem is probably that Gazebo is expecting its argument to point to an SDF file, but finds it to be a directory instead, and crashes as a result.
