In my textbook about industrial robots it says that if the angle q5 in this robot is equal to 0, there are infinite solutions for the angles q4 and q6. I understand this part, but I have a problem with the equation below.
As a solution for this the book says f(q4,q6) = c1*(q4A - q4)^2 + c2*(q6A-q6)^2 = MIN
q4A and q6A are the joint angles calculated from the previous backward transformation when driving a robot path.
By the above equation, a solution for q4 and q6 is taken which is closest to the previous solution.
Between two IK solutions (intermediate points) on a line that the TCP must travel, Q4 must rotate from -pi/2 to -3/2*pi, and Q6 must rotate from pi/2 to -pi/2. Both joints must therefore cover a rotation of -pi.
So the formula would be: c1*(-pi/2 - (-3/2*pi))^2 + c2*(pi/2-(-pi/2))^2
Since I do not know c1 and c2 and the book does not tell me how to determine them, I cannot calculate a solution. How do I calculate the angles for Q4 and Q6?
  • $\begingroup$ Hi, Can you provide the name of the book, author and page? There is missing information to your question and is hard to answer. $\endgroup$
    – jdios
    Feb 17, 2020 at 14:00
  • $\begingroup$ Industrieroboter: Methoden der Steuerung und Regelung from Wolfgang Weber. Page 47 equation 3.3, its german... $\endgroup$
    – Hey Hey
    Feb 17, 2020 at 14:03
  • $\begingroup$ I tried to find the book to see the full equations but I couldn't. Unfortunately I cannot provide an answer since I am lacking the full context. I believe these c1 and c2 comes as constant terms in the previous equations in the book. $\endgroup$
    – jdios
    Feb 24, 2020 at 11:03
