working with hardware like arduino is completely new for me.
i bought a arduino kit with "generic components"... and with it is have a stepper motor called "28byj-48" (https://images.app.goo.gl/y7tDxtL9sewgb4HS7)... i want to work on something that can open and close a small window. (to control humidity in a greenhouse)
... so i figure i should add some king of cog or gear on top of the spinning part of the "28byj-48" and have that move something to push the window open.
... but this is where i am stuck.... i have no idea on what to search for. i have tried the following (...and more): "stepper motor gear", "arduino component gear", "28byj-48 attachment".
i don't really know much about mechanical engineering for creating some kind of arm mechanism... and it is difficult to learn because i don't know the search terms for what i am looking for.
i hope i have have been more clear above by specifying the motor name and the "greenhouse window opening" intention.
please ask if more information is needed and any guidance here would be great.
thanks in advanced.
robot pinion gear
and28byj-48 datasheet
$\endgroup$ – jsotola Jan 22 '20 at 21:38robot pinion gear
into a push/pull motion against the window frame. i will look further into28byj-48 datasheet
. $\endgroup$ – X0r0N Jan 22 '20 at 21:39rack and pinion
andleadscrew
... also consider how an inkjet printhead is moved $\endgroup$ – jsotola Jan 22 '20 at 21:55
