For a 6DoF robot with all revolute joints the Jacobian is given by: $$ \mathbf{J} = \begin{bmatrix} \hat{z_0} \times (\vec{o_6}-\vec{o_0}) & \ldots & \hat{z_5} \times (\vec{o_6}-\vec{o_5})\\ \hat{z_0} & \ldots & \hat{z_5} \end{bmatrix} $$ where $z_i$ is the unit z axis of joint $i+1$(using DH params), $o_i$ is the origin of the coordinate frame connected to joint $i+1$, and $o_6$ is the origin of the end effector. The jacobian matrix is the relationship between the Cartesian velocity vector and the joint velocity vector: $$ \dot{\mathbf{X}}= \begin{bmatrix} \dot{x}\\ \dot{y}\\ \dot{z}\\ \dot{r_x}\\ \dot{r_y}\\ \dot{r_z} \end{bmatrix} = \mathbf{J} \begin{bmatrix} \dot{\theta_1}\\ \dot{\theta_2}\\ \dot{\theta_3}\\ \dot{\theta_4}\\ \dot{\theta_5}\\ \dot{\theta_6}\\ \end{bmatrix} = \mathbf{J}\dot{\mathbf{\Theta}} $$
Here is a singularity position of a Staubli TX90XL 6DoF robot:
$$ \mathbf{J} = \begin{bmatrix} -50 & -425 & -750 & 0 & -100 & 0\\ 612.92 & 0 & 0 & 0 & 0 & 0\\ 0 & -562.92 & 0 & 0 & 0 & 0\\ 0 & 0 & 0 & 0 & 0 & 0\\ 0 & 1 & 1 & 0 & 1 & 0\\ 1 & 0 & 0 & -1 & 0 & -1 \end{bmatrix} $$
You can easily see that the 4th row corresponding to $\dot{r_x}$ is all zeros, which is exactly the lost degree of freedom in this position.
However, other cases are not so straightforward.
\mathbf{J} =
\begin{bmatrix}
-50 & -324.52 & -649.52 & 0 & -86.603 & 0\\
987.92 & 0 & 0 & 0 & 0 & 0\\
0 & -937.92 & -375 & 0 & -50 & 0\\
0 & 0 & 0 & 0.5 & 0 & 0.5\\
1 & 0 & 0 & -0.866 & 0 & -0.866
\end{bmatrix}
Here you can clearly see that joint 4 and joint 6 are aligned because the 4th and 6th columns are the same. But it's not clear which Cartesian degree of freedom is lost (it should be a rotation about the end effector's x axis in red).
Even less straightforward are singularities at workspace limits.
$$ \mathbf{J} = \begin{bmatrix} -50 & 650 & 325 & 0 & 0 & 0\\ 1275.8 & 0 & 0 & 50 & 0 & 0\\ 0 & -1225.8 & -662.92 & 0 & -100 & 0\\ 0 & 0 & 0 & 0.86603 & 0 & 1\\ 0 & 1 & 1 & 0 & 1 & 0\\ 1 & 0 & 0 & 0.5 & 0 & 0 \end{bmatrix} $$
In this case, the robot is able to rotate $\dot{-r_y}$ but not $\dot{+r_y}$. There are no rows full of zeros, or equal columns, or any clear linearly dependent columns/rows.
Is there a way to determine which degrees of freedom are lost by looking at the jacobian?
