I am using an MPU6050 IMU. I did a small experiment having Z-axis pointing upwards. 1. Rotate 90deg around Z-axis (yaw) and back to the original position 2. Rotate 90deg around X-axis (roll) and back to the original position
The issue is that accel data is perfect and I could see data as expected. But, the gyro data shows rotation only around Y-axis. I am a bit confused. Is this expected and need some post-processing to get the Euler angles. OR is there an issue, Please explain.
enter image description here
Accel Data enter image description here
  • $\begingroup$ are you certain that you are reading the gyro module output correctly? $\endgroup$
    – jsotola
    Jan 9, 2020 at 18:17
  • $\begingroup$ Yes. The final result of the rotation angle is perfect. But, the only issue is that the Y-axis has both the values from that of the Z and X-axis. I would be certain that there is a mismatch in the axis if all 3 rotations were distributed among diff axes. But single-axis giving 2 values is misleading. And I am reading accel and gyro data in a single chunk. Accel values look fine. $\endgroup$
    – manojh93
    Jan 14, 2020 at 8:48
