I have 8 dynamixels that are connected together. Everything worked fine until I changed all their ids to 200,201,202, ... To change their ids, I used this python library. Now, none of my motors are detected. I tried testing one motor at a time and I have the same results for all motors.
I tried running factory_reset.py from DynamixelSDK and the script returned:
Succeeded to open the port
Succeeded to change the baudrate Now the controller baudrate is : 1000000
[ID:001] Try factoryreset :
Aborted
[TxRxResult] There is no status packet!
Any idea why I have this error, and how I can fix this? Thank you.
  • $\begingroup$ you did not say how you changed the IDs $\endgroup$
    – jsotola
    Dec 29, 2019 at 22:31
Try a for loop with all possible ids until it is detected.
