I am building a fpv quadcopter and I encountered the following problem:
I soldered all points correctly into their allocated pads and ensured there were no shorts. I use a racerstarf4s flight controller and esc combo which is in relatively good condition.
I used a flysky ia6b receiver which is bound to the transmitter as indicated on both devices.
When I start betaflight and continue to the transmitter section when I move the sticks around on the transmitter no input is detected.
How do I make this detectable, how can I make it control the drone?
Thanks
  • $\begingroup$ How do I make this recognised in the betaflight app. How do I make it control the drone $\endgroup$
    – Tim Li
    Dec 19, 2019 at 23:54
  • $\begingroup$ Will do, can you help me $\endgroup$
    – Tim Li
    Dec 20, 2019 at 0:07
