I'm trying to write a Python formula so that my robot arm can pick up a tennis ball (I'll be adding a gripper soon). The depth camera is mounted near the toolhead.
Any help on writing this formula or how I would write this formula would be appreciated!
Picture:
enter image description here
Here is some sample data that I have collected:
  • Camera center is -6.5 inches from the toolhead
  • The robot coordinate system uses the mounting plate of the robot as its starting point.
  • The camera coordinate system uses the center of the camera as its starting point.
  • The camera xyz orientation is:
  1. The positive x-axis points to the right.
  2. The positive y-axis points down.
  3. The positive z-axis points forward.
The robot xyz orientation is: enter image description here
  1. The positive x-axis points forward.
  2. The positive y-axis points to the left.
  3. The positive z-axis points upward.
---- sample 1 ----
robot start position (inches) xyz, toolhead angle 10.12 0 10.06 -50
what camera sees at robot start position (inches) xyz 10.89 1.37 13.62
robot at ball (inches) xyz, toolhead angle 14.5 .1 1.99 -35
---- sample 2 ----
what camera sees at robot start position (inches) xyz 3.36 -1.07 15.59
robot at ball (inches) xyz, toolhead angle 17.5 4.5 1.99 -35
---- sample 3 ----
what camera sees at robot start position (inches) xyz 7.81 2.0 12.7
robot at ball (inches) xyz, toolhead angle 15.5 2 1.99 -35
