How I can implement a high level PID controller that uses odometry to couple both motors in a diff drive wheeled robot? This is my try: From the motor controller, I can get the estimated speed in ticks/s for each wheel. Then, I calculate the odometry (current linear, angular speed and pose of the robot) from the estimated velocities for each wheel. I compare the current angular velocity of the robot with the target angular velocity. Depending if the error is negative or positive, I will apply the PID controller either to the right or left wheel. Does this approach sounds right?
I also have a low-level PI controller running in a motor controller for motor velocities.
I got the idea from here, page 69:
https://ocw.mit.edu/courses/electrical-engineering-and-computer-science/6-186-mobile-autonomous-systems-laboratory-january-iap-2005/lecture-notes/control.pdf
best,
  • $\begingroup$ Would you please elaborate what you tend to achieve with your PID controller? If you simply like to control a differential drive, please look at differential drive's kinematic equations. Remember this is a non-holonomic system. $\endgroup$ – Franky Dec 5 '19 at 4:13
