I have a trajectory planner, which calculates the trajectory assuming that the robot is following the planned trajectory. From sensors I get the position of the robot, which has an offset from the planned trajectory. I would like to define some limits, and when the "error" is over these limits I would like to send a reset signal to the trajectory planner in order to replan from the actual position of the robot.
Measurements that I can use:
  • Position (x, y)
  • Orientation ( $\theta$)
  • Velocity longitudinal (v)
  • Acceleration longitudinal (a)
The robot is a car-like robot, so my thought goes like this:
  1. Vertical distance $\Delta y$, has the highest priority, in order not to bump on obstacles.
  2. Distance from the point on trajectory $\sqrt{\delta x + \delta y} $
  3. $\Delta \theta$
  4. Velocity and acceleration are not so important.
First of all I would like to know if I am in the correct way about this assumptions, and if there is some literature that I could read on this topic.
Second how can I determine the limits for this errors? I was thinking for y taking the half of the robots' width.
Thanks in advance
