I have read a robotic related paper called Estimating SE(3) elements using a dual quaternion based linear Kalman filter, and the author proposed that the equation of position measurement is denoted as:
$\mathbf{a}=\mathbf{R}\mathbf{b}+\mathbf{t}$
where $\mathbf{a}$ is the sensor measurement, $\mathbf{R}$ ∈ SO(3) is the rotation matrix, $\mathbf{b}$$\mathbf{R}^{3}$is the point to be transformed and $\mathbf{t}$$\mathbf{R}^{3}$ is the translation vector. In an application such as rigid registration of images, $\mathbf{a}$ is the sensed location of points and $\mathbf{b}$ is the corresponding point on the CAD model of the object.
The equation of pose measurement is denoted as:
$\mathbf{AX-XB=0}$
where $\mathbf{A,B}$ are pose-measurements, and the $\mathbf{X}$ is the desired transformation to be estimated.
So is there anyone who know what the difference between pose measurement and position measurement?
referring to your equation $$ \boldsymbol{a}=\boldsymbol{Rb}+\boldsymbol{t} ,$$ the position measurement would be $\boldsymbol{t}$ whilst the orientation measurement would be $\boldsymbol{R}$. These quantities can be obtained in different ways, e.g. position could be measured using GPS while orientation could be obtained using an IMU. I hope this helps,
P.S. feel free to ask further details, I've written my master thesis about a similar estimator.
6
what you are looking for is written in the paper. Position refers only to x,y,z translational measurements while pose means position and orientation.
  • $\begingroup$ Yeah, you're right ! Thanks for your reply ! $\endgroup$
    – Jay Lee
    Nov 24, 2019 at 14:19
  • $\begingroup$ @Jay Lee If this answer has solved your problem, please mark it as 'accepted' by clicking the green check. $\endgroup$ Dec 3, 2019 at 19:20
