I recently purchased an iRobot Create 2. To connect to it, I am using RealTerm Although I can send opcode commands that do not require a Data Byte (128, 173, 133, etc), I cannot figure out the format for opcodes with data bytes
For example, I want to turn on the power LED to full brightness. I have tried the following formats, but to no avail:
139,4,0,254
139 4 0 254
139004000254
13940254
Any direction is appreciated.
enter image description here
Found the answer to my own question. The iRobot needs to be in Safe or Full mode in order to control the LEDs. So, I was entering the numbers correctly (139 4 0 254), but needed to send the command for Safe (131) or Full (132) first.
