I'm currently struggling with implementing the Multiplicative Kalman Filter or Error State Kalman Filter as described by Landis Markley in Attitude Error Representations for Kalman Filtering. Sadly there is two versions of almost the same paper online:
  1. at nasa.gov
  2. at ResearchGate
First of all, I'm a little bit confused why eq. 45 in 1 is different from eq. 33 in 2. Which one is correct? Usually the covariance propagation is defined as $P = FPF^T + GQG^T$. What is the reason for using $P = FP + PF^T + GQG^T$?
In the paper Markley just filters the attitude error and the gyro drift. I would also like to have the angular velocity and acceleration as part of the state. If I understand it right, Markley integrates gyro measurements in the predict step. At the moment I'm trying to figure out the correct way of having the angular velocity as part of the state and then performing a separate update step for the gyroscope.
Currently I have the following code:
import numpy as np
class ESKF:
    """This is an Error State Kalman Filter (ESKF) as described by Markley
    see https://www.researchgate.net/publication/245432681_Attitude_Error_Representations_for_Kalman_Filtering
    def __init__(self):
        # 3 x attitude error, 3 x gyro bias, 3 x angular velocity
        self.x = np.zeros(9)
        # reference quaternion
        self.qref = np.array([0.0, 0.0, 0.0, 1.0])
        # state covariance
        self.P = np.identity(9)
        # process noise
        self.Q = np.identity(9) * 0.01 # TODO should be determined by tests
        # sensor noise
        self.R_gyr = np.identity(3) * 0.01 # TODO should be determined for sensor
        self.R_acc = np.identity(3) * 0.01 # TODO should be determined for sensor
        self.R_mag = np.identity(3) * 0.01 # TODO should be determined for sensor
    #TODO initialization
    def predict(self, dt):
        """The ESKF predict step
        Parameters
        dt : float
             The time step in s
        # eq. 23
        self.qref += 0.5 * quat_mult(np.array([self.x[6], self.x[7], self.x[8], 0]), self.qref) * dt
        # normalize to compensate numerical errors
        self.qref /= np.linalg.norm(self.qref)
        # eq. 38
        F = np.zeros((9,9))
        # df/da
        F[0:3,0:3] = - vec_to_cross_matrix(self.x[6:9])
        # df/db
        F[0:3,3:6] = - np.identity(3)
        # df/dw
        F[0:3,6:9] = vec_to_cross_matrix(self.x[0:3])
        #eq. 39
        G = np.zeros((9,9))
        G[0:3,0:3] = -np.identity(3)
        G[3:6,3:6] = np.identity(3)
        G[6:9,6:9] = np.identity(3)
        # eq. 33
        self.P = F @ self.P + self.P @ F.T + G @ self.Q @ G.T
        #self.P = F @ self.P @ F.T + G @ self.Q @ G.T
    def update_gyro(self, z):
        """The ESKF update step for a gyrosope
        Parameters
        z : array, shape [3]
            Sensor measurement with structure [x, y, z]
        # Kalman Gain
        # K = np.zeros((3,3))
        H = np.zeros((3,6))
        # expected measurement is angular velocity + gyro drift
        H[0:3,0:3] = np.identity(3)
        H[0:3,3:6] = np.identity(3)
        # K = P * H' (H * P * H' + R)^-
        K = self.P[3:9,3:9] @ H.T @ np.linalg.inv(H @ self.P[3:9,3:9] @ H.T + self.R_gyr)
        # x = x + K * (z - H * x)
        self.x[3:9] += K @ (z - H @ self.x[3:9])
        # P = (I - KH)P
        IKH = np.identity(6) - K @ H
        self.P[3:9,3:9] = IKH @ self.P[3:9,3:9]
    def update_acc(self, z):
        """The ESKF update step for an accelerometer
        Parameters
        vi = np.array([0, 0, -9.81]) # TODO + acc
        # eq. 42
        vb_pred = rotvec_to_mat(self.x[0:3]) @ quat_to_mat(self.qref) @ vi
        # h(v) = v
        h = vb_pred
        # Ha
        # eq. 44
        Ha = vec_to_cross_matrix(vb_pred)
        #eq. 46
        K = self.P[0:6,0:3] @ Ha.T @ np.linalg.inv(Ha @ self.P[0:3,0:3] @ Ha.T + self.R_acc)
        # eq. 47
        self.x[0:6] += K @ (z - h - Ha @ self.x[0:3])
        # eq. 48
        self.P[0:6,0:6] -= K @ Ha @ self.P[0:3,0:6]
    def update_mag(self, z, B, incl, W, V):
        """The ESKF update step for a magnetometer
        see https://www.nxp.com/docs/en/application-note/AN4246.pdf
        Parameters
        B : float
            The geomagnetic field strength in gauss
        incl : float
               The inclination angle in rad
        W : array, shape [3,3]
            The soft-iron distortion
        V : array, shape [3]
            The hard-iron distortion
        vi = B * np.array([np.cos(incl), 0, -np.sin(incl)])
        # eq. 42
        #h(v) = W * v + V
        h = W @ vb_pred + V
        # Ha
        # eq. 44
        Ha = W @ vec_to_cross_matrix(vb_pred)
        #eq. 46
        K = self.P[0:6,0:3] @ Ha.T @ np.linalg.inv(Ha @ self.P[0:3,0:3] @ Ha.T + self.R_mag)
        # eq. 47
        # eq. 48
    def reset(self):
        """The ESKF reset step
        # eq. 14
        self.qref = quat_mult(gibbs_vec_to_quat(self.x[0:3]), self.qref)
        self.x[0:3] = np.zeros(3)
and some helpers defined the following:
def quat_mult(a, b):
    """Multiply 2 quaternions. They should have the structure [v1, v2, v3, w]
    Parameters
    a : array, shape [4]
        Quaternion 1
    b : array, shape [4]
        Quaternion 2
    Returns
    q : array, shape [4]
        Quaternion product of a and b
    # eq. 6
    v = a[3] * b[0:3] + b[3] * a[0:3] - np.cross(a[0:3], b[0:3])
    w = a[3] * b[3] - a[0:3].T @ b[0:3]
    return np.array([ v[0], v[1], v[2], w ])
def vec_to_cross_matrix(a):
    """Constructs the skew symmetric cross product matrix of a
    Parameters
    a : array, shape [3]
        Vector
    Returns
    M : array, shape [3,3]
        Cross product matrix of a
    # eq. 5
    return np.array([[0, -a[2], a[1]], [a[2], 0, -a[0]], [-a[1], a[0], 0]])
def quat_to_mat(a):
    """Converts a quaternion into a rotation matrix
    Parameters
        Quaternion
    Returns
        The rotation matrix of a
    # eq. 4
    return (a[3]**2 - a[0]**2 - a[1]**2 - a[2]**2) * np.identity(3) - 2 * a[3] * vec_to_cross_matrix(a[0:3]) + 2 * a[0:3] @ a[0:3].T
def rotvec_to_mat(a):
    """Converts a rotation vector into a rotation matrix
    Parameters
        Rotation vector
    Returns
    # eq. 20
    a_norm_sqr = a[0]**2 + a[1]**2 + a[2]**2
    return np.identity(3) - vec_to_cross_matrix(a) - 0.5 * (a_norm_sqr * np.identity(3) - a @ a.T)
def gibbs_vec_to_quat(a):
    """Converts a gibbs vector into a quaternion
    Parameters
        Gibbs vector
    Returns
        The quaternion of a with structure [v1, v2, v3, w]
    # eq. 18b
    return (1 / np.sqrt(4 + a_norm_sqr)) * np.concatenate((a, [2]))
Obviously, the angular velocity and the gyro drift always have the same values. Is it worth to keep both in the state, or should I just abandon the gyro drift?
I also miss one step in the derivation of eq. 43 in 2. Let $A(a) = \{ I_{3 \times 3} - [\mathbf{a} \times] - \frac{1}{2} ( a^2 I_{3 \times 3} - \mathbf{a}\mathbf{a}^T ) \}$. Then the Taylor expansion is $h(v_B) = h(\bar{v}_B) + \frac{\delta h}{\delta v} |_{\bar{v}_B} (A(a) - I_{3 \times 3}) \bar{v}_B$ since $v_B = A(a)A(q_{ref})v_I = A(a)\bar{v}_B$. But how is this collapsed too just $[\mathbf{a} \times] \bar{v}_B$?
When I let $v_I = (\begin{smallmatrix} 0 & 0 & -9.81 \end{smallmatrix})^T + (\begin{smallmatrix} accx & accy & accz \end{smallmatrix})^T$ and $acc$ is part of my state, then I also have to include $\frac{\delta h}{\delta acc}$ to $H$ (eq. 45 in 2), right? Taking this derivative looks fairly complicated. Is there a smarter way doing it? EDIT: It's not, it's just $\frac{\delta h}{\delta v} A(a) A(q_{ref})$
Thanks in advance, Martin
  • $\begingroup$ I haven't read the papers, but the difference between equation 45 and 33 looks like discrete time vs continuous time. $\endgroup$
    – fibonatic
    Nov 12, 2019 at 1:01
  • $\begingroup$ I don't think so. The whole paper is about the discrete case. For me eq. 45 looks like integrating the sensor noise ($R$) into the covariance update. But at this point he hasn't defined what $R$ is. $\endgroup$ Nov 12, 2019 at 8:19
  • $\begingroup$ To partly answer my question: $(A(a) - I_{3 \times 3}) \bar{v}_B$ becomes $[a \times] \bar{v}_B$ by neglecting the second order term $- \frac{1}{2}(a^2I_{3 \times 3} - \mathbf{a}\mathbf{a}^T)$ in the approximation. $\endgroup$ Nov 12, 2019 at 8:23
After some work I got it working. You can find the C++ source code on github. Don't use the python code in the question. It has some flaws.
In the end I just abandoned the gyro drift (I would argue that this is unobservable with just one gyro). Furthermore I used the classic covariance propagation $P_{k+1} = FP_kF^T + GQG^T$.
-1
@fibonatic was absolutely correct in the comments about the NASA paper talking about the continuous version of it.
By just one look of the equation, I could tell since all of the variables were a function of time and it is a differential equation.
  • $\begingroup$ I'm sorry, I was a bit unprecise. Indeed all formulas regarding the time update / predict phase are written in continuous form, whereas the formulas about the correction steps are in discrete form. But this is the same in both papers. $\endgroup$ Nov 18, 2019 at 16:14
