I’m building an fpv racing drone and I accidentally ordered a 2.4ghz controller and a 5.8ghz video transmitter. Will they work together?
I have 5.8ghz fpv goggles so I assume they will work.
Robotics Stack Exchange is a question and answer site for professional robotic engineers, hobbyists, researchers and students. It only takes a minute to sign up.
Sign up to join this communityI’m building an fpv racing drone and I accidentally ordered a 2.4ghz controller and a 5.8ghz video transmitter. Will they work together?
I am not sure about the details of your setup, but two devices can communicate to each other only if they use the same frequency band(s) and the same (read: matching) signal encoding.
On the other hand, you can use (as example) 2.4GHz for commands and feedback and 5.8GHz for video transmission.
