I am having some troubles understanding a concept regarding the path planning for a unicycle. Suppose I want to plan a path that brings a unicycle from the origin to the point $\begin{pmatrix} 1\\ 1\\ \frac{\pi }{2} \end{pmatrix}$.
The way I operate is the following:
Since we are considering a path planning, we can consider the geometric kinematic model of a unicycle:
${x}'= cos\theta \cdot \tilde{v}$
${y}'= sin\theta \cdot \tilde{v}$
${\theta }'=\tilde{\omega }$
and to solve this problem we exploit the fact that x and y are flat outputs. So we can use third order polynomials to define the path with the parameter $s\in [0,1]$. After, we define the boundary conditions:
$x(0) = x_{i} = 0$
$x(1) = x_{f} = 1$
${x}'(0)= cos\theta _{i}=k$
${x}'(1)= cos\theta _{f}=0$
and the same for y:
$y(0) = y_{i} = 0$
$y(1) = y_{f} = 1$
${y}'(0)= cos\theta _{i}=0$
${y}'(1)= cos\theta _{f}=k$
and now we can define the polynimials:
$x(s)=(k-2)s^{3}+(3-2k)s^{2}+ks$
$y(s)=(k-2)s^{3}+(3-k)s^{2}$
the first derivatives:
${x}'(s)=3(k-2)s^{2}+2(3-2k)s+k$
${y}'(s)=3(k-2)s^{2}+2(3-k)s$
the second derivatives:
${x}''(s)=6(k-2)s+2(3-2k)$
${y}''(s)=6(k-2)s+2(3-k)$
at this point to find the evolution of $\theta $ is :
$\theta = atan2\left \{ {y}(s)',{x}(s)' \right \}$
Now, my question is : What values do we have to put inside the $atan2$ ? So, in particular, how do I compute ${y}(s)'$ and ${x}(s)'$ manually without using a program?
Can somebody please help me? Thank's in advance.
    $\begingroup$ You have your equation for $x'$ and $y'$, And I think that you mean $\theta ' (s) = atan2(x'(s) ,y'(s))$ and you calculate $x', y'$ for a specific $s \in[0,1] $ $\endgroup$ – nionios Oct 31 '19 at 12:30
