I am using Dynamixel MX 64 AR with Open CM 9.04 + Open CM Exp using Arduino IDE. I am using the following code to find Dynamixel ID and Baud Rate:
#include <DynamixelWorkbench.h>
#define DXL_BUS_SERIAL1 "1"            //Dynamixel on Serial1(USART1) <-OpenCM9.04
#define DXL_BUS_SERIAL2 "2"            //Dynamixel on Serial2(USART2)  <-LN101,BT210
#define DXL_BUS_SERIAL3 "3"            //Dynamixel on Serial3(USART3)  <-OpenCM 485EXP
#define DXL_BUS_SERIAL4 "/dev/ttyUSB0" //Dynamixel on Serial3(USART3)  <-OpenCR
#define BAUDRATE_NUM 3
 DynamixelWorkbench dxl_wb;
 void setup()
 Serial.begin(57600);
 while(!Serial); // Open a Serial Monitor
 uint8_t scanned_id[16] = {0, };
 uint8_t dxl_cnt = 0;
 uint32_t baud[BAUDRATE_NUM] = {9600, 57600, 1000000};
 uint8_t index = 0;
 uint8_t range = 100;
 while (index < BAUDRATE_NUM)
Serial.println(String(baud[index]) + " bps");
dxl_wb.begin(DXL_BUS_SERIAL3, baud[index]);
dxl_wb.scan(&scanned_id[0], &dxl_cnt, range);
for (int i = 0; i < dxl_cnt; i++)
  Serial.println("   id : " + String(scanned_id[i]) + "   Model Name : " + String(dxl_wb.getModelName(scanned_id[i])));
index++;
  Serial.println("End");
void loop()
The code is getting compiled successfully but when I am uploading it, it shows the following error :
Unable to connect to bootloader
stm32ld ver 1.0.1
OpenCM Download Ver 1.0.4 2015.06.16
Fail to connect OpenCM
Can anyone help me where I am going wrong? I am just following the tutorial on http://emanual.robotis.com/docs/en/software/arduino_ide/
| improve this question | | | | |
