I am using a Logitech F710 joystick game controller in ROS Kinetic Kame. I was able to perform jstest testing, and can see my joystick works well.
But when I try to use joystick with Turtlesim or with simple teleop_twist_joy, I see this error :[ERROR] [1567106281.990244467]: Couldn't open joystick force feedback! and there is no response on the screen in turtlesim or in the terminal itself.
Here's entire terminal log:
$user@user: roslaunch teleop_twist_joy teleop.launch ... logging to /home/sma1/.ros/log/2bdd147a-ca8f-11e9-80dc-5891cf766ee3/roslaunch-user-14722.log
Press Ctrl-C to interrupt
started roslaunch server http://user:44089/
SUMMARY
PARAMETERS
 * /joy_node/autorepeat_rate: 20
 * /joy_node/deadzone: 0.3
 * /joy_node/dev: /dev/input/js0
 * /rosdistro: kinetic
 * /rosversion: 1.12.14
 * /teleop_twist_joy/axis_angular: 0
 * /teleop_twist_joy/axis_linear: 1
 * /teleop_twist_joy/enable_button: 8
 * /teleop_twist_joy/enable_turbo_button: 10
 * /teleop_twist_joy/scale_angular: 0.4
 * /teleop_twist_joy/scale_linear: 0.7
 * /teleop_twist_joy/scale_linear_turbo: 1.5
NODES
    joy_node (joy/joy_node)
    teleop_twist_joy (teleop_twist_joy/teleop_node)
process[joy_node-1]: started with pid [14739]
process[teleop_twist_joy-2]: started with pid [14740]
  • $\begingroup$ Welcome to Robotics, Deep. What troubleshooting have you done? I googled your error and found this page towards the top of the results, with the following comment on the accepted answer: The problem was that I had not set ROS_IP on my remote machine. Have you tried checking these or other settings mentioned in that post? $\endgroup$ – Chuck Aug 29 '19 at 20:37
  • $\begingroup$ Thank you @Chuck for welcoming me. Before posting it here, I did following troubleshooting: - checked if the controller is actually working with the ROS by following this tutorial: wiki.ros.org/joy/Tutorials/ConfiguringALinuxJoystick - did a quick google search, and found that and many other post, and most of them said to ignore this error, but in my case it doesn't help. - The one you posted is for actual turtlebot, and in my case I am using simulation, looks like ROS is unable to open the controller. $\endgroup$ – Deep Aug 29 '19 at 20:39
  • $\begingroup$ I am trying to use a Logitech F710 controller to a single machine, which runs ROS Kinetic Kame and turtlesim or teleop_twist_joy node in the same environment. $\endgroup$ – Deep Aug 29 '19 at 20:44
  • $\begingroup$ I checked issues list on ros-drivers github page, and everyone says to ignore, but then why I am unable to see any response with teleop node? It only works with jstest $\endgroup$ – Deep Aug 29 '19 at 20:46
I think your ROS joy node isn't configured correctly, which would explain the failure with teleop_twist_joy, because that package subscribes to sensor_msgs/Joy. You said that the joystick is working with jstest, but that's a test to see if your machine can use the joystick. It's not a ROS test.
You said you followed the Configure a Joystick tutorial; what do you get when you do the following (from the tutorial):
Now let's make the joystick accessible for the ROS joy node. Start by listing the permissions of the joystick:
$ ls -l /dev/input/jsX
You will see something similar to:
crw-rw-XX- 1 root dialout 188, 0 2009-08-14 12:04 /dev/input/jsX
If XX is rw: the js device is configured properly.
If XX is --: the js device is not configured properly and you need to:
$ sudo chmod a+rw /dev/input/jsX
What do you get when you try to listen to the sensor_msgs/Joy output?
$ rostopic echo joy
| improve this answer | |
  • $\begingroup$ I followed that tutorial, and was able to see the keystroke values on the console with rostopic echo joy. That made me say that it works with the ROS. $\endgroup$ – Deep Aug 31 '19 at 4:29
  • $\begingroup$ @Deep - you haven't addressed the points I made. What do you get when you check permissions? What do you get when you echo the joy topic? $\endgroup$ – Chuck Aug 31 '19 at 17:19
