I have a Kinect camera which has a minimum depth of 0.5m and I'm trying to find a way to decrease it to around 0.2m for near-depth detection. Does anyone know how this can be done? Can a macro lens be added to the IR camera to decrease the minimum depth? Would I then need to calibrate the extrinsics?
$\begingroup$ I can somehow be done, but you will spent so much time and money that it will be easier to buy a camera with a shorter minimal distance. $\endgroup$– FooTheBarAug 29, 2019 at 14:40
$\begingroup$ @FooBar Oh. Which part of the 'hack' is the difficult part? $\endgroup$– John M.Aug 29, 2019 at 14:47
$\begingroup$ Everything. Finding lenses, fixing lenses, redoing intrinsic calibration for projector and camera. Maybe also somehow lowering the exposure for the IR-camera. Depending on the pattern, the projected dots could be to close to be reliable separated.... So just invest 100$ and get a new camera. $\endgroup$– FooTheBarAug 29, 2019 at 14:49
$\begingroup$ @FooBar Agree. You can do it but will experience all sort of problems. $\endgroup$– Chanoh ParkAug 30, 2019 at 9:11
