I have doubts on how to find all the joint velocities that don't produce any linear velocity, so are in the Null space, when we are in a singular configuration. For example, suppose we have a 2R planar robotic arm. If we compute the Jacobian we have:
$J(q)= \begin{bmatrix}-l_1sin(q1)-l_2sin(q1+q2) & -l_2sin(q1+q2)\\ l_1cos(q1)+l_2cos(q1+q2) & l_2cos(q1+q2)\end{bmatrix} $
and if we consider the sigular configuration for which $q_2=0$ we have:
$J(q)= \begin{bmatrix}-(l_1+l_2)sin(q1) & -l_2sin(q1)\\ (l_1+l_2)cos(q1) & l_2cos(q1)\end{bmatrix} $
now i want to find the joint velocities that produce no linear velocity of the end-effector, so all the velocities that arein the Null space. I have that those are all the velocities of the type :
$N(J)= \alpha \begin{bmatrix} l_2\\ -(l_1+l_2) \end{bmatrix}$
but i don't understand how this result is obtained.
Can somebody please help me?
Thank's in advance.
Quite easily, by applying the definition of the Null Space straight away, you have to solve for: $$ \mathbf{J} \left( q_1,q_2=0\right) \cdot \left[\dot{q_1}, \dot{q_2} \right]^T = 0. $$ You'll come up with the following relation: $$ \frac{\dot{q_1}}{\dot{q_2}} = - \frac{l_2}{l_1+l_2}, $$ which in turn can be summarized by $\mathcal{N} \left( \mathbf{J} \right)$.
