5
I have heard of both the terms AI (artificial intelligence) based robots and control based robots.
Although they are both different fields, what is the difference between AI and control in regards to application (since both are doing same task of automation)?
  • $\begingroup$ Can someone recommend literature where maybe some comparisons have been made? Prefarebly on the control level but everything else would be usefull too. Thanks $\endgroup$ Jan 22, 2021 at 15:49
  • $\begingroup$ @JanikSobhan-Sarbandi see here and references therein. $\endgroup$
    – A. Pesare
    Mar 30, 2021 at 14:33
3 Answers 3
11
In robotics, it all boils down to making the hardware(in essence, the actuator) perform the desired action. The basics of control systems tell us that the transfer function decides the relationship between the output and the input given the plant, i.e. system reacts to the latter.
While purely control-based robots use the system model to define their input-output relations, AI-based robots may or may not use the system model and rather manipulate the robot based on the experience they have with the system while training or possibly enhance it in real-time as well. Eventually, both of them can do the same task.
The difference in terms of applicability is the deterministic behavior of pure conventional control techniques. AI robots have a certain element of stochastic behavior given that they have learned things and learnings can be poor based on a lot of intrinsic and extrinsic factors. AI methods are converging towards high probabilistic success, but not quite there for critical applications.
Also, AI has scope for more inclusiveness of other perception and hardware layers than conventional control that needs everything to be hand-crafted.
7
I think, it is easier to explain these areas in terms of guidance, navigation and control layers for an autonomous robot. Let's stay an autonomous robot is commanded to reach a desired goal position from where it is.
Guidance (what to do): this layers computes a motion plan (a sequence of positions) that starts from the current position of the robot and reaches the desired goal position.
Navigation (where am I): this layer computes an estimate of the robot's state (x,y, heading, speed, etc).
Control (how to do): this layer computes the actuation commands in order to follow the generated path (computed by the guidance layer) based on the estimated state (computed by the navigation layer).
Arguably, AI is heavily used at the guidance layer whereas classical control algorithms (such as LQR, PID) are used in the control layer. Each layer works at different frequency! Again, arguably, engineers tend to use simpler algorithms at the lower layers since they need to execute at higher rates. Also, it is easier to prove closed-loop system stability and performance for simpler control algorithms.
Guidance layer: graph-search algorithms, A*, Dijkstra, MDPs (more AI is used here)
Navigation layer: filtering algorithms, Kalman Filter, EKF, Unscented KF, particle filter, etc.
Control layer: linear control algorithms (PID, LQR), optimal control (MPC), adaptive control (more classical control theory is used here)
5
  • $\begingroup$ lower layers mean?guidance at top layer and control at bottom layer? $\endgroup$
    – engr
    Aug 23, 2019 at 7:33
  • $\begingroup$ Yes. Guidance layer computes high-level plans and control layer computes low-level motion commands. Control layer can also have multiple sublayers. For example, for spacecraft control, there are multiple control laws: translation controller, attitude controller, control allocation, thruster controller, etc. $\endgroup$
    – Octavius
    Aug 23, 2019 at 8:14
  • $\begingroup$ I would argue, that machine learning based approaches are a novel thing in control theory and in the control layer more and more machine learning based approaches are currently being developed (e.g PILCO). As for the navigation layer, machine learning based approaches as state estimators are also getting more and more attention, so I would not divide AI and non-AI based on these layers. $\endgroup$
    – 50k4
    Aug 23, 2019 at 11:22
  • $\begingroup$ I agree. AI, ML based methods are blended across many areas. I listed only the methods I've seen mostly in each layer for the sake of brevity. $\endgroup$
    – Octavius
    Aug 23, 2019 at 15:29
  • $\begingroup$ MPC is also used in guidance layer for path trajectory generation $\endgroup$
    – drerD
    Aug 26, 2019 at 1:58
In a control engineering sense AI (or in this case learning based approaches) and classical control based approaches are just different sides of the same coin.
In control theory the problem is to control a system (sometimes called the plant) to behave in a desired way. The desired way is given (in form of a reference value, which can change over time).
The simplest form of closed loop control is to take the current, measured value subtract this from the reference value and the error signal is created. This difference is the beginning of any closed loop control. Simplest is to multiply this with a constant to make sure that if there is an error between these two the system will try to "move" in order to get to the reference value.
There are many advanced and complicated approaches to achieve this. Simplest above is the P (proportional) controller but one can complicate this further with integrative and derivative terms and end up with the so called PID controller (still the most used in industrial practice). Control systems have evolved and model based predictive, optimal etc. control approaches have been developed.
However, the control problem can be formulated as a machine learning problem and this is how machine learning can be mixed with control theory. Probably one of the fundamentally new approaches is the PILCO approach presented here.
So.. for low level control learning and classical control is somewhat interchangeable. (Machine learning based control systems can behave fully deterministically after training)
In higher levels closed loop control has sometimes been used, but mostly, for robots planning methods generate paths to be followed by the closed loop controllers. These paths can be hard-coded like in the case of most industrial robots or more flexibly defined as in the case of service robots. Planning problems and their solutions have always been a subfield of AI, therefore it can be argued that any robot which solves a planning problem is AI-based. Machine learning itself is also a subfield of AI. Machine learning methods can also solve planning problems.
If we take grasping as an example. Detecting grasp point can be done using classical machine vision, with no machine learning or with a neural network based approach e.g. 2. These methods are interchangeable ans dome perform better then the others in different situation.
Any robot which ever navigated a labyrinth is AI-based. Way-finding in a labyrinth is a classical AI planning problem. Somewhat novel are the machine learning based solutions for these well known planing problems.
In areas such as speech recognition or gesture recognition is a similar situation. These have been always part of AI, the novelty, also here is the success of machine learning based approaches. Here again, methods, classical vs. machine learning based are interchangeable, but the latter have a much better success for these applications.
