The RoboClaw data sheet from ServoCity mentions various current limits, but what about voltage? Can I run a 110 Vdc treadmill motor?
    $\begingroup$ first page has this specification Up to 34VDC Operation $\endgroup$
    – jsotola
    Aug 16, 2019 at 17:12
  • $\begingroup$ Does “operation” mean the output voltage? $\endgroup$
    – Nic
    Aug 18, 2019 at 1:00
  • $\begingroup$ i am sure that it means operated by or powered by .... in other words, maximum power supply voltage $\endgroup$
    – jsotola
    Aug 18, 2019 at 2:26
As mentioned on page 7 of the datasheet,
The main power input can be from 6VDC to 34VDC on a standard RoboClaw and 10.5VDC to 60VDC or 80VDC on an HV (High Voltage) RoboClaw.
  • $\begingroup$ Is it safe to assume the motor output voltage is not greater than the input voltage? $\endgroup$
    – Nic
    Aug 18, 2019 at 1:01
