For example, a robot or a humankind is grasping an object such as a bottle.
Which forces are effective on that bottle ?
This is my opinion:
When we grasp a bottle, we exert a force on contact point. This force can be decomposed into "normal force" and "tangent force". The tangent force points in z-axis. The normal force is perpendicular to the bottle itself.
Normal force creates a friction force on contact point. We can think like there are 3 forces applied on the object in z-axis: Friction force, tangent force, and weight of the object.
<-------- Tangent force . Weight -------->
If weight is bigger than Tangent force, friction force points to right (-->)
If tangent force is bigger than weight, friction force points to left (<--)
<-----------------------------------------------> z-axis
  • $\begingroup$ You can use Newtons method to find a pretty good model...I would suggest just starting with a steel cylinder or square block and reduce down to two contact points of a specific force F like a robot gripper...don't forget decide where your coordinate system is or adding gravity..... See if your methods apply still. $\endgroup$ – morbo Aug 7 at 17:39
