i am trying to make an angle meter, using the UNO and MPU6050, following joop brokking video tutorials,
when utilizing the accelerometer, the results are fine,
however when i try to use gyroscope (each one alone) do not get the expected result
when rotating the sensor from 0 to 90 degrees, the output change from 0 to 60~70 degrees only
so what is wrong is it the code, the gyroscope is damaged
here is the code
 refresh ();
 angle += (gyro_x - cal_x) * (millis () - timer) / 1000.0;
 Serial.println (angle);
refresh (); is a function that updates gyro_x
the MPU6050 is fixed so that it rotatea in one direction only
later on i took this false measure and applied it in a complementary filter, the result was plausible, and varies around 0.5 degrees, i still need to get it to an accuracy of 0.0x
This will be a bit troublesome to help with, as you didn't post all of your code or more importantly your exact errors (Serial.print()), but for general infos, and for others it's enough. Questions regarding troubleshooting your wiring/c code directly, I think should be directed to arduino.stackexchange.com There are countless questions and answers there.
You need to integrate the gyro if you plan on getting an angle...
An example code (in wiring) to integrate your gyroscope readings would be, with 0.01 being your sampling constant $\Delta t$
void update_int(double *u, double *y)
static double x[1] = {0};
double x1[1];
y[0] = x[0];
x1[0] = x[0] + 0.01*u[0];
x[0] = x1[0];
However keep this in mind, gyros are accurate short term, but long term have 'drift' and will become unreliable.
You can read more infos about this at adafruits gyroscope comparison site.
Generally one "fuses" several different sensor readings to make one, such as your 'complimentary filter'
Other options are the Madgwick Filter and the Kalman Filter....achieving a variance of +/- 0 dps is nearly impossible, but you can get pretty close using some clever techniques and one of the mentioned filters. A comparison of all three filtering techniques can be found at OlliW's website.
