I'm working with ROS melodic and Gazebo 9.9.0 on an Ubuntu 18.04.2 LTS.
I want to get two boolean parameters from command line. To do it, I have this code:
  bool doDiagonalSteps = false;
  bool checkDiagonalCornerUnBlocked = false;
   * We must call one of the versions of ros::init() before using any other
   * part of the ROS system.
  ros::init(argc, argv, "astar_controller");
   * NodeHandle is the main access point to communications with the ROS system.
  ros::NodeHandle n;
   * Get parameters (if there are parameters to get.)
  if (!n.getParam("diagonalSteps", doDiagonalSteps))
  else
    std::cout << "Diagonal steps: " <<  std::endl;
  if (!n.getParam("checkDiagonalStepCorner", checkDiagonalCornerUnBlocked))
  else
    std::cout << "Diagonal Corner: " << checkDiagonalCornerUnBlocked << std::endl;
When I run this command on terminal:
rosrun nav_astar_nodes astar_controller _diagonalSteps:=true _checkDiagonalStepCorner:=false
I don't get anything on the output.
How can I get a boolean parameter from command line?
When you create the node handle, you need to set it to the private namespace:
ros::NodeHandle n("~");
Then the call to n.getParam("diagonalSteps", doDiagonalSteps) will look for the parameter in the namespace /astar_controller (the name of your node) where it was set when you passed an under-scored variable to it from the command line, instead of the global namespace which is what happens by default.
