On the lower-right of the screen, there is an "Archive" button, from which I go to the dialog box/window where there are Delete, Delete all, Export and Load options, but there is no "Export All" ...
The robot in question is manufactured by:
https://www.cmarobot.it/intelligent_painting_robot/index.php
If I attach a keyboard to the robot computer, can I mark everything by Ctrl + A keyboard combination ? Or maybe with Shift + Arrow up/down... ?
I can provide more photos if necessary.
Thank you.
enter image description here
  • $\begingroup$ it seems like you have access to the device .... why are you asking us about the keyboard and about possible key combinations? $\endgroup$
    – jsotola
    Jul 6 '19 at 19:53
  • $\begingroup$ My guess is that this is a touchscreen @jsotola. $\endgroup$
    – Mark Booth
    Jul 7 '19 at 13:41
  • $\begingroup$ Yes, I confirm - it is a touch display. I will try with a keyboard and keep you posted about it. $\endgroup$
    – FREEMAN
    Jul 7 '19 at 17:02
Solved !
No need to connect a keyboard.
I went to D:\cmafiles\STATS and there is the whole list of files with the working statistics in XLS format. I've copied all of them on my USB Flash memory.
Thank you everyone.
