Can anybody recommend a robotic arm to be possibly coupled with VR to be used for educational purposes for university students within a bucket of about 15000€?
I've made a bit of a list of what's available for teaching robots.
| improve this answer | |
  • $\begingroup$ You should copy and paste your bit of a list here as linking to a link that links to another link which might end up dead someday will make your answer useless to people in the future. $\endgroup$ – morbo Jun 30 '19 at 21:16
The default decision would be a UR5. It is a bit out or your range, but it could be worth to check with UR if they give you a university discount. Main advantage is the huge user base, rather good support in ROS and easy things like following waypoints can be done in python within hours of unpackaging.
  • $\begingroup$ How much out of range? $\endgroup$ – drSlump Jul 1 '19 at 11:54
  • $\begingroup$ They are normally a bit over 20k Euro, but that's for commercial buyers. $\endgroup$ – FooTheBar Jul 1 '19 at 13:27
