I'm new to ROS and robotics and I'm trying to implement the ROS navigation stack in a 3 wheeled omnidirectional robot. I already made the map using RTABMap but now I'm stuck in the 'Publishing Odometry Information over ROS' step. Currently the robot ouputs odometry data in geometry_msgs/Pose2D (http://docs.ros.org/kinetic/api/geometry_msgs/html/msg/Pose2D.html) format.
Here are some of the codes compiled in STM32:
//Calculate Odometry
void calculate_odometry(void)
short int odometry0_speed = odometry0;
odometry0 = 0;
short int odometry1_speed = odometry1;
odometry1 = 0;
float buffer_x[2];
float buffer_y[2];
buffer_x[0] = odometry0_speed * cosf(gyro_radian + 0.785398);
buffer_x[1] = odometry1_speed * cosf(gyro_radian + 2.356190);
buffer_y[0] = odometry0_speed * sinf(gyro_radian + 0.785398);
buffer_y[1] = odometry1_speed * sinf(gyro_radian + 2.356190);
x_buffer_position += (buffer_x[0] + buffer_x[1]) * odometry_to_cm;
y_buffer_position -= (buffer_y[0] + buffer_y[1]) * odometry_to_cm;
x_position = x_buffer_position - x_offset_position;
y_position = y_buffer_position - y_offset_position;
//RECEIVE data FROM gyro
void DMA1_Stream1_IRQHandler(void)
if (DMA_GetITStatus(DMA1_Stream1, DMA_IT_TCIF1))
if (gyro_status == RESET)
gyro_status = SET;
buzzer(22, 22);
memcpy(&gyro_buffer, gyro_receive + 3, 4);
gyro_angle = (gyro_offset - gyro_buffer);
gyro_radian = (gyro_offset - gyro_buffer) * 0.01745329252;
while (gyro_angle > 180)
gyro_angle -= 360;
while (gyro_angle < -180)
gyro_angle += 360;
while (gyro_radian > 3.14159265359)
gyro_radian -= 6.28318530718;
while (gyro_radian < -3.14159265359)
gyro_radian += 6.28318530718;
USART_DMACmd(USART3, USART_DMAReq_Rx, DISABLE);
USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
DMA_ClearITPendingBit(DMA1_Stream1, DMA_IT_TCIF1);
//ROS SUBSCRIBER CALLBACK
void cllbck_sub_velocity(const geometry_msgs::Twist &msg)
x_velocity = msg.linear.x;
y_velocity = msg.linear.y;
angular_velocity = msg.angular.z;
motor_timer = 0;
The gyro data is from GY-521 + Arduino.
From these code I should be able to get
x -> x_position dx -> x_velocity
y -> y_position dy -> y_velocity
A -> gyro_angle ω -> angular_velocity
right?
And then how can I publish the data in nav_msgs/Odometry (http://docs.ros.org/kinetic/api/nav_msgs/html/msg/Odometry.html) format? Do I have all the data I need correctly?
Should I use the code in http://wiki.ros.org/navigation/Tutorials/RobotSetup/Odom, what need to be changed or included in the code?
Or can I do autonomous navigation by only using visual odometry from RTABMap?
