I'm searching a navigation method to find my location while dead reckogning (gps signals jammed) with an imu and gsm based navigation results. In short i have 3 sources:
  • Gsm Based Navigation ( gives lat lon data at @5hz, around 100m accuracy)
  • Imu(gyro+accelerometer)
  • GPS Receiver
There are filters like kalman, complimentary etc. but many use this methods when they have 2 source (gps/imu)in my case i have 3. What is simplest way to integrate gsm based pos and imu data in dr and should i use a filter or not. Thanks.
You should definitely use a filter. You need to adjust to the noises. If you can design or know the state space models of the agent and the sensors then KF is the easiest to use.
  • $\begingroup$ Thanks for response. Can you give a simple model for begining. $\endgroup$
    – K.Ense
    Commented Jun 28, 2019 at 7:40
