I'm looking for what a robot that moves like a plotter but can grab a load up to 1kg with a claw, lift, rotate and place in another location within its range. What is this type of robot called?
enter image description here
  • 4
    $\begingroup$ XY gantry robot $\endgroup$ – jsotola May 20 '19 at 3:28
  • $\begingroup$ @jsotola Good answer. Why not make it a "real" answer next time? $\endgroup$ – Ben May 26 '19 at 12:10
Cartesian robots have the characteristic that their axes move in Cartesian (x-y-z) directions.
The picture is of a Gantry robot, but for your workcase you can use manipulator like ABB pick and place robot for more dexterity.
  • $\begingroup$ Aren't gantry robots just normal robots suspended on en external linear axis? $\endgroup$ – 50k4 May 20 '19 at 7:09
    $\begingroup$ 1kg is a lot for these delta robots (especially if add the weight of the gripper to the weight of the object) and they have very limited workspaces. As OP did not give a lot of information the task, proposing this robot is just a guess. $\endgroup$ – FooTheBar May 20 '19 at 7:21
