I followed this tutorial: Basic ROS MoveIt! and Gazebo Integration
but when I launch moveit launch file from tutorial, I have error which says that I did not specify parameter '~moveit_controller_manager', but I did it in abb_irb120_3_58_moveit_controller_manager.launch.xml.
this is complete text of the error:
Parameter '~moveit_controller_manager' not specified. This is needed to identify the plugin to use for interacting with controllers. No paths can be executed.
I did not create abb_irb120_3_58_moveit_controller_manager.launch.xml on my own, I just copied content from tutorial in launch.xml file.
this is content of abb_irb120_3_58_moveit_controller_manager.launch.xml:
<launch>
 <group ns="/abb_120_moveit_ns">
  <!-- load controller_list -->
  <rosparam file="$(find abb_120_moveit)/config/ros_controllers.yaml"/>
  <!-- Set the param that trajectory_execution_manager needs to find the controller plugin -->
  <arg name="moveit_controller_manager" default="moveit_simple_controller_manager/MoveItSimpleControllerManager" />
  <param name="moveit_controller_manager" value="$(arg moveit_controller_manager)"/>
 </group>
</launch>
Does anyone knows what I have to do to specify parameter '~moveit_controller_manager'? I really do not have any idea anymore.
  • $\begingroup$ What is the name of the node that is consuming that parameter? $\endgroup$ – adamconkey Jul 27 '19 at 14:41
