Is there any difference between "tinyGPS++.h","tinyGPS.h", and "Adafruit_GPS.h"? Can I use the same code to extract the current GPS location for all these libraries?
$\begingroup$ have you actually done any research before you posted your question? .....most libraries come with example code .... compare the example code for the three libraries $\endgroup$ – jsotola Apr 25 '19 at 23:35
Before asking this question and seeking for someone experience here . I recommend you to do some search . First the creator of the tinygps library provides a complete wiki page full of informations including many functions and the difference between the tinygps and tinygps++ go here all the gps library work correctly but always people improve library's due to some problems exist or to add more features to improve the coding reliability. So don't worry about the difference but choose the right library for your project.
