Do "configuration" and "pose" means the same thing? If not what is the difference?
$\begingroup$ This might be a good question, but unfortunately it is not clear what you are asking. We prefer practical, answerable questions based on actual problems that you face, so it's a good idea to include details of what you want to understand, what you've researched so far, what you found & what you expected to find. Please take a look at How to Ask & tour for more information on how stack exchange works and work through the Robotics question checklist to edit your question to make it clearer. $\endgroup$– Ben ♦Apr 18, 2019 at 16:19
1 Answer
No.
One of the most clear definitions of 'pose' that I've heard is in Peter Corke's Robotics, Vision and Control (RVC). It states that:
"The position and orientation of a coordinate frame is known as its pose and is shown graphically as a set of coordinate axes. The relative pose of a frame with respect to a reference coordinate frame is denoted by the symbol ξ".
The following figure is figure 2.2 in RVC:
The point P can be described by coordinate vectors relative to either frame {A} or {B}. The pose of {B} relative to {A} is $ ^{A} ξ _{B} $
The 'configuration' of a robot is a set of scalar parameters that specify the positions of all of the robot's points relative to some fixed coordinate system. This can be expressed as a vector of positions and orientations, for example:
q = ($x$, $y$, $\theta$)
or
q = (($x$, $y$, $z$, $\alpha$, $\beta$, $\gamma$))
The set of all possible configurations is the 'configuration space', or 'C-space'.
If we consider the two-link planar manipulator with 2 revolute joints (2R-arm), shown here (taken from fig 7.3 in RVC):
The configuration can be expressed in terms of just the two joint angles $\theta _{1}$ and $\theta _{2}$, while the configuration space is the set of all possible combinations of the joint angles $\theta _{1}$ and $\theta _{2}$.
Note that configurations are not necessarily unique. For this robot, there are two possible configurations that result in the same end-effector position, but the end effector will have a different orientation in each case.
A worked example using MATLAB can be found in the Analyzing a 2-joint planar robot arm lesson on Peter's QUT Robot academy. This includes a visual description of the 2R-arm shown above.
