I am currently working with the Rutgers APC 2015 data set for pose estimation, and see that the pose estimates, specifically the rotation estimates, have seemingly been rescaled to range between -1 and 1. Does anyone know if these values were arrived at by dividing by 180?
Check whether they are in radians. Most algorithms use radians for pose estimation.
The range between -1 or +1 is a normalized range like you said. The question is the following: Were those values divided by 180 (degrees) or 2*pi (radians)? You should check any existant documentation regarding Rutgers APC 2015. Usually, the convention is to have the angles bounded between -pi/pi or -180/180, because expressions like atan2 or atan2d returns angles in that range. The range 0-360 might lead to tricky bugs to catch and error during the 360,0 crossover.
