So I did the algorithm for the vehicle to go in a clockwise direction(Refer to my pseudocodes below). But now that my school had said there will be an anti-clockwise direction as well, I'm not sure what to do. Do I only reverse the logic of my pseudocode below? Do I use switch cases as well? I'm not sure. So the vehicle must be able to move both clockwise and anti-clockwise around the 'maze'
Maze project
/* Check if the left sensor is blocked*/
if(left sensor ==true )
    if(Obstacle detected)
        move_forward;
/* Check if the back-left sensor is blocked*/
if(back-left sensor ==true)
        move_diagonal_front_left;
/* Check if the front-left sensor is blocked*/
if(front-left sensor== true )
        move_diagonal_front_right;
/* Check if the front sensor is blocked*/
if(front sensor== true )
        move_right;
/* Check if the front-right sensor is blocked*/
if(front-right sensor== true )
        move_diagonal_back_right;
/* Check if the right sensor is blocked*/
if(right sensor== true )
        move_back;
/* Check if the back-right sensor is blocked*/
if(back-right sensor== true )
        move_diagonal_back_left;
    else if(Obstacle cleared)
        Move_backwards;
  • $\begingroup$ what does this mean? Do I use switch cases as well? $\endgroup$
    – jsotola
    Mar 23, 2019 at 7:23
  • $\begingroup$ @jsotola its like switch(switchval) { case 1:, case 2 etc.. default } $\endgroup$ Mar 23, 2019 at 7:25
  • $\begingroup$ it is impossible to guess what changes you need to make to your code .... all i can suggest is that you check which side you are starting at and then follow the wall on the same side $\endgroup$
    – jsotola
    Mar 23, 2019 at 7:44
