When using the Yaskawa Smart Pendant SDK API (Java client), it is possible to set multi-byte I/O values via:
controller.setOutputGroups(outNum, 2, value16bits);
controller.setOutputGroups(outNum, 4, value32bits);
However, sometimes the byte ordering is wrong. Depending on the product vendor or if using Ethernet/IP or IOLink, multi-byte values can be big-endian or little-endian.
How can I swap the ordering?
The API doesn't have any direct support for endian conversion / byte-swapping. However, there are some Java functions that can handle it:
Short.reverseBytes(short i16)
Integer.reverseBytes(int i32)
Long.reverseBytes(long i64)
So, the calls in the question would become:
controller.setOutputGroups(outNum, 2, Short.reverseBytes(value16bits));
controller.setOutputGroups(outNum, 4, Integer.reverseBytes(value32bits));
