-1
This is my school project. I would like arducopter connect to raspberry but I do not know how to do it. Please help me!
    $\begingroup$ you have to explain what this means exactly arducopter connect to raspberry ...... also explain what you are trying to accomplish $\endgroup$ – jsotola Feb 18 at 4:05
  • $\begingroup$ I want to see the gps data from arducopter at raspberrypi $\endgroup$ – Recep Orak Feb 18 at 7:24
To do so, you need to use a USB link between the Ardupilot/Arducopter and use the MAVLink protocol to interrogate the Arducopter in order that it sends back its GPS data. You can etheir way use the C libs of MAVLink, the Python implementation or the ROS one (named mavros). You may find some clues here:
Depending on your programming skills this may requires you some time to reach your aim!
