Being new into the ActoboticsTM set, it's not always clear to me what the parts are supposed to do.
I'm currently in need of placing a servo inside a channel facing outwards, as depicted on the picture below. The servo mount is A type. But I could not recognize what part is that silver tube next to the servo, and if that is screwed on the bottom of the channel.
Could you please advice?
Servo mount A on a channel. Credit: SparkFun
  • $\begingroup$ the answer is obvious ... ask yourself, Can I buy the channel with the silver standoff already attached? .... if you cannot, then the standoff is a separate item $\endgroup$ – jsotola Feb 12 at 1:30
  • $\begingroup$ 'Standoff', that is the name I coudn't remember. I tested using CAD models and it seems that the 6-32, 1-1/8'' Aluminium Thread Standoff is just the right size to fit servo inside the channel. Thanks for the reply - if you'd care to make it an answer it would be accepted. $\endgroup$ – Diego Alves Feb 12 at 15:15
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
