I'm stuck with the following problem:
In a Kalman Filter, we assume the following holds:
The state vector can be filled with values which are returned by actual sensors. The Transition matrix needs to be set up according to a motion model. Same holds for the control input matrix. But how can I determine w_t and v_t ? How do I know which values to choose for the covariance matrices Q and R ?
I hope someone can help
