-1
I use a TowerPro sg90.
1.5 ms for the centre position 0 degree, and 2 ms pulse for +90 degree and -90 degree with a 1ms pulse.
But it's definitely not looking like it goes for 90 degree or -90 degree.
I did read, some said "I tested two of them for about 130.000 cycles, without load, at one cyle per second, and 70 degrees travel." .
What does that mean "130.000 cycles at one cycle per second"?
  • $\begingroup$ it means exactly what it says ..... which part do you not understand? $\endgroup$
    – jsotola
    Dec 25 '18 at 8:01
They use "cycle" to mean moved left then right.
They moved it left then right 130,000 times. They did it at a rate of once per second. They moved it 70 degrees, without any load attached.
