I'm building quadcopter and most of the control systems use one accelerometer and gyro. I've read few papers and usually accelerometer is used as reference to the ground because gyro slowly drifts away in time. But if quadcopter does some crazy maneuvering when force direction from accelerometer does not have to point to the ground than accelerometer data is useless. As well there is problem with centripetal force if the accelerometer is not directly in the centor of mass.
I was thinking about using multiple accelerometers. To fully determine position and motion of quadcopter one would need three accelerometers(If I have done the math right). This would kind of solve the problem with centripetal force
So I would like to know if anyone tried to use multiple accelerometers for better orientation estimation.
You definitely mean the orientation and not position. Any yes, people have used multiple accelerometers to determine the orientation, for example Wii's "nunchuck" is an attachment to the Wiimote that has an additional accelerometer, so that the orientation of the stick can be calculated
You won't be able to determine the position of the quadcopter with accelerometers or gyros or a combination of both.
You can use either accelerometers or a combination of accelerometers and gyros to determine the orientation (eg. roll, pitch, yaw) of the quadcopter. The gyro will allow for a more nimble quadcopter because it provides additional information at a faster rate.
You can think of it like this: The accelerometers are useful for determining your orientation when moving slow (stable response, no drift, low bandwidth). The gyros are useful for determining your orientation when your moving fast (provide high bandwidth updates but have significant drift over longer time periods). The combination of the two using something like a complementary filter will provide the best of both worlds however you will need 6 axes of measurement (3-axis gyro, 3-axis accelerometer). Also, since gravity is symmetric about the vertical axis you would need a magnetometer or compass sensor to zero the gyro drift about that axis and provide reliable heading control. There are several off-shelf Intertial Measurement Units (IMU) that can be purchased and interfaced to your main controller.
If you use only accelerometers your quadcopter won't be as agile as if you used a combination of gyros and accelerometers since the bandwidth of accelerometers are generally lower than that of gyros. Most ready-to-fly quads use accelerometers, gyros, and magnetometers.
