Where can I find a good documentation about the UWSim in ROS. Actually having the source files is not enough and it is actually hard to follow all the functions. for example, how can I use these command correctly :
& rosrun UWSim gotoAbsolutePosition 0 0 0 0 0 0
I know that there is a node 'gotoAbsolutePosition' in the Package 'UWSim' and I knwo the variables, but I cannot set the two topics properly.
  • 2
    $\begingroup$ You may want to check out the UWSim wiki page or ask your question on the ROS forum. $\endgroup$
    – Ian
    Aug 27, 2013 at 18:12
  • $\begingroup$ There is no such help in the wiki page, but at ROS forum maybe you are right. $\endgroup$
    – NKN
    Aug 27, 2013 at 18:27
The primary entry point for UWSim ROS documentation is at: https://wiki.ros.org/uwsim This has the basic commands for running it too.
There are example programs such as gotoAbsolutePosition which are mostly thin wrappers on the ROS api for convenience.
You can find all the examples of using the interface here: https://github.com/uji-ros-pkg/underwater_simulation/tree/melodic-devel/uwsim/interface_examples
And it's main documentation wiki is at: http://www.irs.uji.es/uwsim/wiki/index.php?title=Main_Page
With a guide for interacting with the simulator on this subpage: http://www.irs.uji.es/uwsim/wiki/index.php?title=First_steps:_Interacting_with_UWSim
